eCart 6 Shipping Quote
Thread began 9/17/2014 5:34 pm by dDog | Last modified 9/19/2014 4:07 pm by Jason Byrnes | 823 views | 7 replies |
dDog
Hello,
I completed the eCart 6 Wizard and generated the checkout pages, including UPS shipping, however nothing having to do with UPS shipping (other than shipping address) is appearing in the checkout routine. I was careful to select "UPS" Shipping from the checkout wizard and I entered in the UPS login and api information. My question is when should the shipping quote appear in the checkout process and what should I do to included this in the checkout process?
http://blue-water-marine.com/products_results.php
dDog
See PM
UPS had made an update to their system to not accept weight in ounces. We updated the WA_eCart/WA_eCart_UPS_PHP.php file to convert ounces to pounds to fix the problem
after you complete the checkout form, it should automatically do an ajax post to update the shipping in the cart display, when you click continue it will post the transaction to paypal.
dDog
Wow! It's working now!
I completed the form and behold the shipping amount appeared at the bottom! Woah! What files should I d/l to ensure I have them up-to-date locally? What did I do wrong?
it was nothing you did wrong, like I said, UPS recently made an update to their system that is causing using Ounces for the weight to fail.
we updated the WA_eCart/WA_eCart_UPS_PHP.php file to convert ounces to pounds.
dDog
Thank you for your help! Again Webassist to the rescue!
- Benjamin
you're welcome.
