MySQLi Log Out User - How to apply to a button?
Thread began 9/15/2014 5:58 am by Nathon Jones Web Design | Last modified 9/15/2014 9:06 am by Jason Byrnes | 1383 views | 3 replies |
Sorry, little bit confused with the MySQLi Log Out User behaviour. The old DW behaviour allowed you to apply the Log Out to a link or graphic but that doesn't seem to be an option with the MySQLi Log Out User behaviour which triggers are:
?Any form post: The server behavior is applied to a form on the current page to trigger the data insert.
?Before page load: The server behavior is applied to the current page to trigger the data insert when the page loads.
?Current page submit: The server behavior is triggered when a page is submitted.
?Rules: Multiple conditional rules based on other WebAssist Server Behaviors.
?Dynamic Data interface: If the triggers in the list do not meet your requirements, use the lightning bolt to specify server-side code.
How do apply the Log Out user behaviour to text and/or graphic so I can set up a "Log Out" button or link?
Thank you
NJ
normally, you would set the logout link or button to go to a log out page, on the logout page add the logout behavior, and use the before page load trigger.
Easy when you know how. Thanks Jason.
NJ
you're welcome.
