Manage Relational Table with file fields problem
Hi, I used Manage relational table to insert and update pictures, the page has check box and a file field. The file field enables when you check the checkbox to avoid inserting blanks into the database it works fine when you insert the information into the database, but when I have to update, since there is no file selected in file field that has data in the database, if I press the submit button the name of the picture is erased from the database. If I un check the checkbox, the column will be erased from the database as it should.
My question is how to avoid to erase the name of the picture from the database if I don't select a new picture and the checkbox is checked?
