Logout - mySQLi Server Behaviors
Thread began 9/13/2014 7:48 am by Andrew | Last modified 9/18/2014 1:52 pm by Jason Byrnes | 776 views | 7 replies |
Andrew
How can I modify the Logout so that on logging out user is taken to a new page?
add the restrict access behavior, and make sure it is after the logout behavior.
in the restrict access behavior you can set a failed redirect.
Andrew
Hi Jason,
Thanks for your reply.
I applied your advice and with a little bit of adjustment to what I had done before, it now works.
Thanks.
However ...
it has thrown up the problem that if user1 logs out and user2 logs in without closing the browser in between users, then user2's login attempt takes him straight to the logout page. There is no code on any html/php pages in the site that have a link to the logout page (it is done via js).
I assume that it is something to do the browser cache.
It shouldn't be a major problem but have you any advice?
Andrew
Andrew
See below
in actual fact, that behavior is as designed, since the restrict access is used to perform the redirect
On logging in, it will try to go to the last restricted page.
the work around would be to hard code the redirect on the logout page rather than using the restrict access as previously sugested:
if ($_SERVER["REQUEST_METHOD"] == "POST") {
header('Location: ../index.html');
Andrew
It worked.
Thank you
you're welcome.
