show / hide content based on a drop down
Thread began 9/12/2014 5:22 am by Jamie | Last modified 9/15/2014 1:02 pm by Jason Byrnes | 3263 views | 8 replies |
Jamie
Hey Jason
On the attached _insert and _results pages I have used a checkbox (named 'GuestSpeaker') to show/hide to text fields (NonMemberName and NonMemberCompany) which I got and adjusted slightly from another thread (http://www.webassist.com/forums/posts.php?id=32553) This works great but I have 2 questions.
1. I have a drop down (MemberName) on the same page which has an option Guest Speaker (this is in row 1 of the table in the datbase) and would like to use that instead of the check box to determine the show/hide for the above and update the column in the database for 'GuestSepaker' as the current checkbox does.
2. on the _update page, at the moment if the GuestSpeaker is checked (in the database set to 1) and you go to an entry that has this set, it doesnt automatically show the hidden fields even though the checkbox is pre-ticked. How would I get it to automatically show the content if the db column is set to 1?
Jamie
presentations_insert.php
presentations_update.php
here is an example script using a select list value to toggle a txt field visibility, notice that I call the setTextField() function just before the body tag, this is to trigger the function to show it onload of the page if the selected option is 3, change the selected option to see this in action.
<!doctype html>
<html>
<head>
<meta charset="UTF-8">
function setTextField() {
var theList = document.getElementById("select");
var theText = document.getElementById("textfield");
var theSelectedValue = theList.options[theList.selectedIndex].value;
if(theSelectedValue == "3") {
theText.style.display = "block";
} else {
theText.style.display = "none";
</script>
</head>
<body>
<form name="form1" method="post" action="">
<p>
<select name="select" id="select" onChange="setTextField();">
<option value="1">One</option>
<option value="2">Two</option>
<option value="3" selected="selected">Three</option>
<option value="4">Four</option>
</select>
</p>
<p>
<input type="text" name="textfield" id="textfield" style="display: none;">
</p>
</form>
setTextField();
</script>
</body>
</html>
Jamie
thats brilliant. many thanks Jason
how would you update to use a y/n radio set?
like this:
<!doctype html>
<html>
<head>
function setTextField(theVal) {
if(theVal == "y") {
} else {
</script>
</head>
<body>
<p>
<label>
<input name="RadioGroup1" type="radio" id="RadioGroup1_0" onChange="setTextField(this.value);" value="y" checked>
Yes</label>
<br>
<label>
<input type="radio" name="RadioGroup1" value="n" id="RadioGroup1_1" onChange="setTextField(this.value);">
No</label>
<br>
</p>
<p>
</p>
</form>
setTextField("y");
</script>
</body>
</html>
Jamie
thanks Jason. if the radio is defaulted to no, how do you get the hidden content to default to hidden until yes is selected
also, see PM
set:
setTextField("y");
</script>
setTextField("n");
</script>
or use this:
var theGroup = document.getElementsByName("RadioGroup1");
var selectedItem = 0;
for(i = 0; i < theGroup.length; i++) {
if(theGroup[i].checked) {
selectedItem = theGroup[i].value;
setTextField(selectedItem);
</script>
Jamie
thanks Jason
you're welcome
