URLS not passing properly
Thread began 9/12/2014 12:55 am by Christopher West | Last modified 9/12/2014 2:09 pm by Jason Byrnes | 1445 views | 7 replies |
Hi. Ok hopefully this will make sense while I figure out how to describe my issue.
Im using User Friendly SEOS via HTACCESS (Which works)
here is the code:
Options +FollowSymlinks
Options -Multiviews
RewriteRule ^Category/([^/.]+)/?$ /category.php?Categories=$1 [NC]
RewriteRule ^Product/([^/.]+)/?$ /product.php?Product=$1 [NC]
RewriteRule ^Article/([^/.]+)/?$ /dinky-article.php?Article=$1 [NC]
Therefore my URL is now:
http://www.dinkyfingerprintjewellery.co.uk/Category/Individual-Charm
if you look at this URL on th eright hand side under a set of links there should be some additional content displaying:
SIDE NOTE: If you look at this URL: http://www.dinkyfingerprintjewellery.co.uk/ordering.php you will see what content I mean (So I know it works in part since the right hand side content displays on this page)...it just doesnt display on any of my category pages
in the database the this additional content is selected via a field named "FeaturedLocale" - so for example for all my category pages (since im using HTACCESS to re-write the URLS the FeaturedLocale contains:
Category/Bracelets
Category/Cufflinks
SIDENOTE: my other pages (NOT User Friendly URLS) contain for example:
ordering.php
frequently-asked-questions.php
caring-for-your-silver.php
So those work,
Here is my RecordSet to display this content:
$basefile = basename ( $_SERVER["REQUEST_URI"] );
mysql_select_db($database_dinkydb, $dinkydb);
$query_rsFeatured = "SELECT * FROM featured LEFT OUTER JOIN products ON featured.FeaturedTypeID = products.ProductID WHERE FeaturedType = 1 AND FeaturedLocale = '$basefile'";
$rsFeatured = mysql_query($query_rsFeatured, $dinkydb) or die(mysql_error());
$row_rsFeatured = mysql_fetch_assoc($rsFeatured);
$totalRows_rsFeatured = mysql_num_rows($rsFeatured);
and the PHP to display the content:
<?php if ($totalRows_rsFeatured 0) { // Show if recordset not empty ?>
  <div class="clearfix"></div>
  <div class="hide-mobile-bottom hide-mobile-side">
  <div class="feature-heading">Featured Products</div>
  <?php do { ?>
    <p class="feature-name"><a href="../Product/<?php echo $row_rsFeatured['ProductLink']; ?>"><?php echo $row_rsFeatured['ProductName']; ?></a></p>
    <p class="feature-price">From  £<?php echo $row_rsFeatured['ProductPrice']; ?></p>
    <p class="feature-image"><a href="../
    Product/<?php echo $row_rsFeatured['ProductLink']; ?>"><img  src="../images/products/large/<?php echo $row_rsFeatured['ProductImage']; ?>" width="250" alt="<?php echo $row_rsFeatured['ProductImageTitle']; ?>"/></a></p>
    <?php } while ($row_rsFeatured mysql_fetch_assoc($rsFeatured)); ?>
 </div>
  <?php // Show if recordset not empty ?>
I just dont know what im doing wrong, well obviously it has to do with the HTACCESS User friendly URLS but how can I reference them when I need to store the page location in the database.
Im attaching a screenshot of the database records:
Chris
to troubleshoot, write the recordset SQL to the screen:
<?php echo($query_rsFeatured); ?>
this will help you see what SQL is being used at run time
Hi, I tried this before, here is the result:
SELECT * FROM featured LEFT OUTER JOIN products ON featured.FeaturedTypeID = products.ProductID WHERE FeaturedType = 1 AND FeaturedLocale = 'Individual-Charm'
I just dont know what to do know.
well, i dont see any records where the featured local is = to Individual-Charm.
i see:
you could change the recordset so it uses Ends with:
SELECT * FROM featured LEFT OUTER JOIN products ON featured.FeaturedTypeID = products.ProductID WHERE FeaturedType = 1 AND FeaturedLocale LIKE '%Individual-Charm'
Hi Jason, the LIKE tweak to the recordset works! :)
Side Note: from your suggestion of writing out the recordset, showed that the recordset was checking for "Individual-Charm" ... and the URL ended with: /Category/Individual-Charm ...So they way I looked at that I needed to somehow append /Category/ to the basefile statement (which currently is $basefile = basename ( $_SERVER["REQUEST_URI"] );) However I thought if I did that append then other pages (that was NOT User friendly URLS wouldnt work...ie frequently-asked-questions.php). So even though I got it to work using LIKE.... what could have been a solution to append /Category/ to the basefile variable in my recordset?
Chris
perhaps instead of using
try using
$_SERVER["PHP_SELF"]
That makes more sense, so I was probably using the wrong $_SERVER code. I will probably try that later to check just for piece of mind...but in the mean time your earlier solution works perfectly, So once again thank you Jason for helping me with this so quickly :)
Chris
you're welcome.
