Using SecurityAssist or MySQLi Behavior to restrict access
Thread began 9/11/2014 12:40 pm by joerg431091 | Last modified 9/11/2014 1:33 pm by joerg431091 | 1344 views | 4 replies |
joerg431091
Using DataAssist and SecurityAssist.
I am a little confused about what to do when it comes to creating new insert, update and delete pages as well as applying security to pages / restricting access to pages for users.
Should I still use the DataAssist Pages and the Security Assist - create security pages functionalities from Webassist or should I create those pages to insert, update and delete information in the database as well as restricting access using the new MySQLIi Server Behaviors series tutorials?
Looking at the new MySQLi tutorials for user authentication seems like that it is still easier to use the Security Assist functionality since I can apply those to several pages at the same time but I want to avoid to have everything changed over to MySQLi at least for the once that I am building going forward.
Any advise on this? Should I wait (if possible) until the DataAssist and SecurityAssist functionalities are compatible to MySQLi? What’s the best way to approach this?
Thanks a lot and best regards,
Joerg
If your server still supports MySQL, than you should continue using Data Assist / Security Assist to create new projects.
The MySQLi server behaviors should be used if the server does not support the MySQL library.
we are working on upgrading Data Bridge for MySQLi support, but I don't have a time frame for when it will be released.
joerg431091
Thanks a lot Jason.
I have not really understand the complexity yet of changing from MySQL to MySQLi once MySQL will be deprecated. Once all tools are upgraded and working on MySQLi - do I pretty much have to start from scratch and apply everything I build with eCart and DataBridge for all websites again?
I am just trying to get an understanding of what is coming and whether it is a matter of changing some code in existing websites or changing the entire sites from scratch by building completely new checkout processes, insert update and result pages and security access pages.
Joerg
It's too early to tell what the process will be for upgrading existing sites to use MySQli that where created with MySQL.
Ray is talking about creating an upgrade tool, but the feature set has not been finalized.
joerg431091
Thanks a lot Jason. I am sure you guys will figure out a way to do it as "painless" as possible.
Best,
Joerg
