Difficulty loading existing data into an Edit Form.
Thread began 9/11/2014 8:05 am by Andrew | Last modified 4/02/2015 2:55 pm by Ray Borduin | 1873 views | 14 replies |
Andrew
Hi Jason
Using the WebAssist Update Record feature, I'm having difficulty loading existing data into an Edit Form.
The link that should load the data is:
<a href="edit.php?itemID=<?php echo($rsItems->getColumnVal("itemID")); ?>">Edit this item</a>
and on the Edit Page, this appears in the browser address with the correct value for the item ID. However no data is loaded into the Edit Form.
The php code at the top of the Edit Page reads ....
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$UpdateQuery = new WA_MySQLi_Query($connsheffieldarchives);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "items";
$UpdateQuery->bindColumn("itemID", "s", "".($rsItems->getColumnVal("itemID")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("itemNo", "i", "".((isset($_POST["itemNo"]))?$_POST["itemNo"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("publicPrivate", "s", "".((isset($_POST["public"]))?$_POST["public"]:"") ."", "WA_DEFAULT");
$UpdateQuery->addFilter("itemID", "=", "i", "".($_GET['itemID']) ."");
$UpdateQuery->execute();
$UpdateGoTo = "admin_menu.php";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
$rsItems = new WA_MySQLi_RS("rsItems",$connsheffieldarchives,1);
$rsItems->setQuery("SELECT * FROM items WHERE itemID = ?");
$rsItems->bindParam("i", "".(isset($_GET['itemID'])?$_GET['itemID']:"") ."", "-1"); //colname
$rsItems->execute();?>
Within the form, the data should appear in form fields that read (typically)
<input type="text" name="itemNo" id="itemNo" /> for text
and
<select name="decade" id="decade">
while(!$rsDecade->atEnd()) { //dyn select
<option value="<?php echo($rsDecade->getColumnVal("decadeID")); ?>"<?php if (!(strcmp($rsDecade->getColumnVal("decadeID"), ($rsDecade->getColumnVal("decadeID"))))) {echo "selected=\"selected\"";} ?>><?php echo($rsDecade->getColumnVal("decadeName")); ?></option>
$rsDecade->moveNext();
} //dyn select
$rsDecade->moveFirst();
</select> for tables
If it's any help, the relevant pages can be found at
http://archives.shearwaterwebdesign.co.uk/admin/edit_listing.php
with the link on the bottom of the following page.
Thanks in anticipation
you have to bind the forms to the coresponding recordset elements.
Select each form element, int he property inspector, click the lightning bolt next to Initial Value and select the coresponding recordset column
for the select lists, click the dynamic button and in the Select Item Equal To, select the corresponding column from the rsItems recordset.
Andrew
Hi Jason
Thank you - that worked.
Data is now loaded and can be amended.
Submitting gets
Notice: Undefined variable: rsItems in C:\wamp_php5_5\www\sheffieldarchives\admin\edit.php on line 9
Fatal error: Call to a member function getColumnVal() on a non-object in C:\wamp_php5_5\www\sheffieldarchives\admin\edit.php on line 9
The relevant piece of code is:
$UpdateQuery->bindColumn("itemTitle", "s", "".((isset($_POST["itemName"]))?$_POST["itemName"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("itemDescription", "s", "".((isset($_POST["itemDescription"]))?$_POST["itemDescription"]:"") ."", "WA_DEFAULT");
and rsItems is:
I used to do this with a DW Wizard - that's why I'm struggling (I don't understand php).
Thanks in anticipation.
Andrew
send the full page so i can see the code in context.
Andrew
File attached
the update code is before the code block for the recordset.
instead of using the recordset binding for the ID, create a hidden form element, bind that to the Id column from the recordset, then in the update behavior, set the filter column to use the hidden form element.
on the binding tab, you should not bind the ID column to anything.
Andrew
That's solved it!
Thank you very much!
you're welcome
Ian
Continuing update problem
Apologies if bad form to re-open an old thread but seems appropriate as it seems an identical problem and suggestions above don;t seem to have solved it for me.
I have a record update form which is more or less identical to the add record form (other than dynamic code and minor detail)
I open the update form in Dreamweaver 5.5 and create a record set.
Server behaviours, +, Web Assist, MySQLi, Data Management, MySQLi Update Record.
Trigger – Button: re_button pressed
Connection – PrioryTerrier
Update Table – registers
Lookup column – re_index (default value)
Column type – Integer (default value)
Lookup value - $_GET[‘re_index’} (default value)
After updating go to – list_register_record.php
Column bindings
re_index –
Value = <?php echo((isset($_POST["re_register"]))?$_POST["re_register"]:"") ?>
Submit as Text, Blank value Db Default
Same (apart from field names) for re_period_from, re_period_to, re_location, and date_recorded
date_update has blank value set to Current Date
Testing the page at this stage allows me to correctly select an existing record but the update form does not show existing data but I can complete the fields and these are recorded, over writing the existing record if something new entered or leaving the initial value if nothing new entered in the field.
I then go back to programming and go through the form, selecting each field in turn and clicking the lightning bolt by Initial value in the Properties Inspector and selecting the matching name from the options shown under Form. This includes the hidden field.
Testing again results in the same as before – edit is possible but it is done “blind” as before as no past data is shown.
Because of replies above, I started again, this time first creating a Record set, then binding fields as appropriate, including binding the Id field to a hidden form element as suggested in the above forum thread.
That just digs a bigger hole for myself!
As you will gather, I don’t really know what I am doing when it comes to PHP and MySQL but know enough to have created bega.org.uk for the local church to save them £5000 for a commercial package which is worth it but we can’t afford.
I have attached the offending file!
update_registers_record.php
