it showing up in dreawever cc 2014 but it is showing up on cs6 but is not working?
Do I need to reinstall what am I doing wrong?
After installing the extensions in the extension manager, when you open DW it should launch the WebAssist installer to complete the installation.
If the WebAssist installer does not launch automatically, you may need to open a php page to trigger it.
try uninstalling the extensions then installing them again and make sure the web assist installer completes when you open DW. After the WebAssist installer finishes, you will need to restart DW.
