Curiously, if you add an item from the second accordion tab, it only adds 1 item.
Another strange behaviour is the the accordion doesn't work properly until you have gone to 'view cart', then you can open other tabs.
you have the add to cart cart behavior code inside a recordset repeat region, that will cause it to trigger for each record that it repeats.
Sorry, Jason - I didn't see your reply before I updated; will check agaon.
Chris
That fixed it - and the other issue about the tabs not working as expected.
thanks again
Chris
Hi Jason
It's doing it again - but this time I think it's related to the number of repeated days, as quantity 16 is being entered each time.
I've tried moving the code block to different locations, but then nothing is added to the cart.
Chris
well, again, its because the cart object code is inside a repeat region.
you have a nested recordset that you are using for display, and you are trying too use the same recordset for the add to cart.
In the add to cart, you should use a separate recordset that is not in the repeat.
so basically, you use one recordset to display the information, but another recordset that is not in the repeat region to add the item to the cart.
I'll look at this with you when i loo at the other issues you have posted.
