error WADA_MultiUpdate.htm
Hi, I'm trying to update multiple records but appears an error then updated JavaScript "WADA_MultiUpdate.htm"
Urgent help please!
Urgent help please!
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
I have performed the steps, I even reinstalled again but not solve the problem. I made a short 3 minute video to show the error and the steps I took but did not solve the problem. https://nigma.wistia.com/medias/1bms4dj2l0
before adding the multiple record insert behavior to your page, you need to apply the data assist repeat selection behavior. This error will occur if you use a repeat region on the page instead.
