ecart errors
Thread began 9/04/2014 4:57 pm by mycalidesigns | Last modified 9/06/2014 10:49 am by mycalidesigns | 342 views | 2 replies |
mycalidesigns
ecart errors
keep getting this
Warning: require_once(webassist/ecart/checkout/credentials/gateways.php): failed to open stream: No such file or directory in /home2/lostmexi/public_html/bpce/confirm.php on line 2
Fatal error: require_once(): Failed opening required 'webassist/ecart/checkout/credentials/gateways.php' (include_path='.:/usr/php/54/usr/lib64:/usr/php/54/usr/share/pear') in /home2/lostmexi/public_html/bpce/confirm.php on line 2
I don't need a payment option, I would like to just confirm order and send email to client with items in cart. I got everything working but when i go to check out i keep getting the above errors.
Is there a better way to approach this problem to just email order details to client without a payment process?
When you run the checkout wizard, on the Gateway tab, there is an option to select none so that it will not use a gateway.
make sure to select the None option.
you should delete the existing checkout pages and re run the wizard and select None on the gateway tab.
mycalidesigns
i will give it a try. thanks jason.
