radio group css forms
Thread began 9/02/2014 9:50 pm by nickj | Last modified 9/29/2014 9:01 am by nickj | 2243 views | 6 replies |
nickj
1, Radio group is wrapping around into the first column (see attached image in zip file).
2, Even after changing field to be not required the next time I try to build the page they are required again. I want the default to be not required!
See image in attachment and code from page.
Archive.zip
1) Send a link where I can see the form to troubleshoot the CSS.
2) I Have logged a bug for this issue to have it corrected in the next update.
nickj
Thanks for your quick response. I haven't added an insert yet. I'm assuming I can use the MYSQLi behavior.
Nick
in the webassist/forms/fd_etfformdesign_default.css file, edit the following selectors:
form.ETFFormDesign_Default div.fullColumnGroup
form.ETFFormDesign_Default div.columnGroup
and set the width to 760px
nickj
Not working today, I had to rebuild the files:http://ecoteach.org/admin/Blurbs/blurbs_update.php
nickj
Thanks, the CSS worked great. So, adding the insert and update behaviors are the same as in the past except that I use the MYSQLi behaviors. Right?
Nick
yes, that is correct
