I am getting Warning: Division by zero in
Thread began 9/02/2014 12:35 pm by danny405167 | Last modified 9/02/2014 1:43 pm by Jason Byrnes | 1506 views | 6 replies |
danny405167
What is causing the errors below
Warning: Division by zero in /homepages/34/d356933685/htdocs/danny/webassist/caching/CachedResize_Image.php on line 274
Warning: Division by zero in /homepages/34/d356933685/htdocs/danny/webassist/caching/CachedResize_Image.php on line 278
Warning: imagecreatetruecolor() [function.imagecreatetruecolor]: Invalid image dimensions in /homepages/34/d356933685/htdocs/danny/webassist/caching/CachedResize_Image.php on line 105
Warning: imagecreatefromjpeg() [function.imagecreatefromjpeg]: gd-jpeg: JPEG library reports unrecoverable error: in /homepages/34/d356933685/htdocs/danny/webassist/caching/CachedResize_Image.php on line 106
Warning: imagecreatefromjpeg() [function.imagecreatefromjpeg]: '../../login/profile_pics/' is not a valid JPEG file in /homepages/34/d356933685/htdocs/danny/webassist/caching/CachedResize_Image.php on line 106
Warning: Division by zero in /homepages/34/d356933685/htdocs/danny/webassist/caching/CachedResize_Image.php on line 174
Warning: imagecopyresampled(): supplied argument is not a valid Image resource in /homepages/34/d356933685/htdocs/danny/webassist/caching/CachedResize_Image.php on line 199
Warning: imagejpeg(): supplied argument is not a valid Image resource in /homepages/34/d356933685/htdocs/danny/webassist/caching/CachedResize_Image.php on line 219
danny405167
Ok
danny405167
OK. I found the problem. Since there is no file name in the field of UserImage, image resizer is not able to do the calculation. Thanks for responding asap.
see pm
danny405167
The problem was that when I registered, I left the field name UserImage blank. I have to make the UserImage field name in the database to have a default value to prevent the warning from appearing again.
put an if statement around the image tag to use a default static image if the recordset column is blank:
<?php if($row_SecurityAssistusers['UserImage'] !="") { ?>
<img src="../../login/profile_pics/<?php echo $row_SecurityAssistusers['UserImage']; ?>" class="img-thumbnail" width="200" height="200" alt="pfrofile">
<?php } else { ?>
<img src="../../login/profile_pics/default.jpg" class="img-thumbnail" width="200" height="200" alt="pfrofile">
<?php } ?>
