Remove border from form
Hi
I am using Data Assist to add an email form to a page.
I have added a simple form to a php page using 'insert new form'.
I want to remove the border around the form.
Can I do this, and if so where?
Hi
can't be sure without seeing your page, but it sounds like the fieldset.
take a look at this link...
http://www.webassist.com/forums/posts.php?id=28665
Sorry can't find that code,
I am trying to remove the border around the whole form
page is at http://patrickjefferson.com/new/email.php
I've managed to remove 'Contact me, its the border around the whole form I need to loose.
edit your css file PJ_email_css/screen.css
and add the following selector:
fieldset {
border: none;
Really struggled with this and then realised that If I re-enter the wizard, in formdesign you can put border to 'none in the field set section, this removed the border.
Thanks for you help anyway guys,
best
