Image not showing
Thread began 8/27/2014 9:18 am by willo009412397 | Last modified 8/27/2014 9:39 am by Jason Byrnes | 473 views | 1 replies |
willo009412397
Image not showing
Hi i have not used these extensions in a while, and the tutorials i have found have changed. I am trying to create a results and details page. I have so far made the pages, added the upload behaviour to the file field, it uploads fine so the image is in my images folder. However i cannot seem to get the images to show on results or details pages. I have changed the placeholder to a dynamic image, putting the folder name at the beginning as shown. But still the images do not show pls help. I have added the pages for you too see.
Webassist_help.zip
on the insert page, in the upload behaivor, you have bpound the uploaded file name to Server File Name binding.
this is circular logic, the uplaoded file name is created by the upload, it cannot be used i nthe behacior to set the file name, it is used to return the file name.
in the behavior, set the file name to:
[FileName]
In the insert recpord behavior, you need to use the server file name binding for the ProductImage column, not the form element binding.
The way the insert is set up, the file name wont be saved to the database. make the changes above so the file name can be saved to the database.
