Complete newbie failing to connect local database in DW CS6. Help!
Thread began 8/26/2014 1:25 pm by Cheryl | Last modified 8/26/2014 3:48 pm by Jason Byrnes | 1119 views | 3 replies |
Cheryl
When attempting to connect a database to a php file in DW, I am getting the following error message:
HTTP Error Code 404 File not found. Some possible causes of the problem:
1) No test server is operating on the server computer.
2) The testing server specified for this site does not map the URL http://localhost/actionbay.net/_mmServerScripts/MMHTTPDB.php. Verify that the URL prefix is mapped to the root folder of the site.
I am not sure what I am missing. Please see screenshots.
judging by the error, you have set the WEB URL in the testing server settings to:
but the site files are in the c:/xampp/htdocs/forms-testing folder, that folder would map to the address:
http://localhost/forms-testing
that is the address you should use din the testing Server settings for the web url
Cheryl
Thank you!
Thank you! That got the error message to go away.
Now, I am on to learning how to set up a form.
you're welcome.
