Data Bridge Issue
I get this error message when I try and load the Create Pages function of DB. I have uninstalled and reinstalled the extension twice today.
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
I've reset the layout and there doesn't seem to be a Dreamweaver Cache file in the location mentioned in the tutorial. I have CC2014 running OSX Mavericks. I have also searched for the file directly with no results.
the path for the cache file should be:
/users/[username]/Library/Application Support/Adobe/Dreamweaver CC 2014/en_US/Configuration/
I don't have a Dreamweaver CC 2014 showing. I've attached a screenshot of my finder.
it's not showing the folders in alphbetical order, you may need to scroll down to see the Dreamweaver CC 2014 folder.
