Not able to access validated entries...
Thread began 8/22/2014 5:22 am by Banksie | Last modified 9/02/2014 12:17 pm by Jason Byrnes | 1256 views | 17 replies |
Banksie
I recently had a PC meltdown, had to buy another PC and reinstall everything! Now using Win 8, Dreamweaver CS4 and a number of WA extension including Form Toolkit with which I now get the following problem...
I have a simple form (contact_us.php) and a "processing" page to which it's directed (contact_sent.php) and which includes server validation of the data from contact_us.php (and, if all passes validation, a WAUE behavior forwarding the message on).
contact_us.php has a number of vaildation show if blocks that trigger if any vaildation (on contact_sent.php) triggers. All work fine & as expected.
However! In the past I would easily assigned any returned, validated entries to the fields in contact_us.php (to avoid re-entry of fields that have already been checked and found to be valid) by means of selecting the dynamic data from a validated entries collection that were fed back from contact_sent.php. I now no longer have such a validated entries collection presented to me in the bindings panel (nor when clicking the lightning bolt on the field's property) as options for assigning to the relevant fields.
I've done the usual of deleting the winfilecache and even removed & reinstalled the extension but noting seems to work.
Any ideas??
Regards
Gary
Edit the server behavior and reselect the validation fails redirect page to regenerate the bindings group.
Banksie
Thanks Jason. Done that - has no effect I'm afraid! Any other ideas?
You do have a Site Defined right? and the pages are saved to that site?
do you have other bindings in the bindings panel that work?
try deleting the notes folder from the site, you will need to use the OS File system explorer to access the site files and delete the notes folder, then try editing the server validation behavior again
Banksie
Hi Jason,
Yes, I do have a site and all of these files are saved to that site. Tried deleting the _notes folder and trying it all again - DW recreated a new _notes folder but nothing changed.
I have bound my contact_us.php to the processing form (contact_sent.php) and, when the data entry is correct and validated, I can use that binding to display the relevant fields that have been posted from contact_us.php. When there's invalid data, the contact_us.php form displays the "validation show if" error messages so I assume binding to the validation page is working in some form (although there's no listing in the bindings panel)
As a test, I've created a completely new site and created a very simple form and vaildation page in it. Sadly the same happens; I can process the form data and, if valid, display the bound fileds from the original form in the processing page or, if validation fails, bounce back to the original form and display the "show if" errors based on validation failures.
Any more ideas?
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
Banksie
Sorry, not in the US and don't use skype I'm afraid! Any other ideas? I'm at my desk now in the UK and will be here for another hour if you'd like to call me -
We use skype for international communications, It is free to sign up for a skype account.
what extensions, including the version numbers are installed?
Banksie
I'll check out skype now and advise.
In the meantime I have the following extensions installed:
Pro Maps for Google 1.0.7
Form Toolkit 1.0.0
Cookies Toolkit 3.1.1
Digital File Pro 2.0.4
Security Assist 1.1.9
Universal Email 4.0.1
Data Assist 2.1.0
eCart 5.0.7
You have a conflict in having both Universal Email 4 and Digital File Pro 2 installed.
UE 4 contains the DFP Functionality, that conflict could be the cause of the problem.
I would recreate the users configuration folder as outlined in step 12 of the Adobe troubleshooting guide:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
then uninstall all extension from the extension manager, restart Dreamweaver and close it, then reinstall the extensions leaving Digital File Pro out.
where eCart 5.0.7 is the most recent release, install that one last.
