mysql error message
Thread began 8/21/2014 3:06 pm by vered435903 | Last modified 8/22/2014 1:42 pm by vered435903 | 2646 views | 10 replies |
vered435903
mysql error message
Hello~
I've been updating my admin product update page and suddenly I'm getting an error message. I don't know what I could have done.... This is the error message:
MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 2
I'll attach the file so you can reference it. Also, I'm still getting a spry error message in regards to the ProductUpdateDate - I followed the Inventory Maintenance II tutorial and it seems like all the code wasn't removed, but when I delete the lines that reverence that field, I get an increase in error messages...
vered435903
There isn't a problem online yet because I haven't uploaded the pages with issues.
The problem is occurring in Dreamweaver when I open the files. When I click on the recordset to add bindings to elements, that mysql error pops up and the recordset menu won't expand. I must have moved or deleted something that's responsible for that connection.... that same mysql error is now popping up in pages I haven't edited, so I may have compromised a web assist file somehow?? I haven't uploaded any files from the web assist folder which may be why the site is still functioning without issues.
What files should I send you? Or what should I look for?
I'm also getting this error when I open the document. When I search for the referenced lines and remove them, the page stops functioning.
I had the same issue when I added the inventory management and followed your tutorial to remove fields from the page. You told me to remove the spry references, and I did, which solved the problem. Now this similar error is appearing.
Thanks for your help!
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
vered435903
see pm
I have sent a skype contact request.
vered435903
see pm
I Checked in with Ray, and this is a Dreamweaver issue that can sometimes happen when using a complex query, sometiomes if the query is to cplex, Ddreamweaver will flake out and thrpw SQL Errors when none exist.
Not really any workaround for this except to hand code the bindings as:
<?php echo($row_WADAProducts["ColumnName"]); ?>
where ColumnName is the name of the column
vered435903
Thanks!
Where do I put those lines of code?
where you would like to echo the recordset value
