Session not always being picked up
I have a page that stores a value from a recordset in a session to help send people back to the page they were on after they log in.
Details below....
Details below....
your rs_Lodge recordset is using INNER JOIN, this means it will only return a result if there is a match in all tables, try using LEFT OUTER JOIN instead.
Thanks Jason - I tried that with no luck.
I realised I didn't need the country in that recordset, so have taken out the join altogether, still with no luck.
Revised copy attached.
i added an if statement to set the session only if the RS is not empty:
session_start();
if($row_rs_Lodge['GSG_URL'] != "") {
$_SESSION["Lodge_GSG_URL"] = "".$row_rs_Lodge['GSG_URL']."" ;
session_commit();
that seams to have fixed it.
Thank you Jason - not sure why, but with that the log in broke.
But I tried it without the commit line, and it fixed that.
So don't know what happened there, but all seems OK now.
ok, glad to hear it is working.
