How to get a dd/mm/yyyy date format from a MySQLi Recordset
Thread began 8/20/2014 11:19 am by gary385539 | Last modified 8/21/2014 11:15 am by Jason Byrnes | 5378 views | 5 replies |
gary385539
I am using an MySQLi recordset and when I try to display the date from a field in the recordset using my previous MySQL format code:
<?php echo(($row_RS_MbrList_Curr['dateofbirth'])?date('d/n/Y',strtotime($row_RS_MbrList_Curr['dateofbirth'])):''); ?>
it will not return anything and the page will not load. How do I get the date our of a MySQLi Recordset into dd/mm/yyyy format please?
the code to echo a MySQLi recordset value would look like this:
<?php echo($RecordsetName->getColumnVal("ColumnName")); ?>
where RecordsetName is the name of the recordset and ColumnName is the name of the column, to format that if it is a date:
<?php echo(date("d/m/Y", strtotime($RecordsetName->getColumnVal("ColumnName")))); ?>
gary385539
Thanks you Jason.
Is there a way of calculating the current age of the person from that value too?
Your help is appreciated.
you can do that directly in the recordset if your using MySQL 5 >
SELECT TIMESTAMPDIFF(YEAR, dateColumn, CURDATE()) AS age FROM tableName
gary385539
Thanks again!
you're welcome
