HTML Editor 3.0.2
Thread began 8/19/2014 1:53 pm by randyrie405335 | Last modified 8/19/2014 2:20 pm by Jason Byrnes | 312 views | 1 replies |
randyrie405335
HTML Editor 3.0.2
re: iMAC OSX 10.9.4, DW CS6
I cannot get the editor's menus to show on my PHP webpage - only the text field shows and with only HTML code - not the editable text. Please see my screen capture. Can you suggest how to fix this?
HTML Editor 3 is not compatible with DW CS6, it also contains an outdated version of the CKEditor files that may not be supported in your browser.
I recommend upgrading to Data Bridge which uses a more up to date CK Editor version.
or you can manually upgrade the CK Editor files.
in the webassist/ folder, rename the ckeditor folder to ckeditor_bak
On this page:
download
click the button to launch CK Builder. Select to use the Full Preset, and the Kama Skin.
Copy the downloaded CKEditor folder to the webassist folder in your site.
from the ckeditor_back folder, copy the following three files:
ckeditor.php
ckeditor-php4.php
ckeditor-php5.php
and paste them in the new ckeditor folder.
you will need to clear the browsers cache to see the updates take effect.
