redirect from cart to login
Hello~
I hope you had a good weekend~
We did lots of work on our shopping cart last week.... now, if you click the add to cart and aren't logged in, instead of redirecting to the login page, I get a redirect back to the cart and it displays as a blank page. I made sure the redirect is pointing to the correct login page, but it's still not redirecting correctly. If you go directly to the login, it works so it's not the login page that has a problem... What else do I need to check that can be causing a glitch in the redirect?
Thanks!
