Check boxes
Hi I am using DW CC, windows 8.1 mysqli server behaviors.
I am upgrading a custom CMS system i have built
I am trying to get a check box to work, in the update behavior. I am seeing the following issues.
Although the "Submit as Check Box Y,N" is upper case Y,N in the behavior it is submitting lower case "y".
When i choose Blank Value "N" nothing is being sent to the db, eg if there was a "y" in the db after update, there is no value
