Recordset paging
Thread began 8/12/2014 9:39 am by gail.bergan407744 | Last modified 8/13/2014 9:08 am by Jason Byrnes | 1301 views | 3 replies |
gail.bergan407744
Recordset paging
I'm going through your tutorial on putting recordset pagination on a page. The behavior WebAssist > MySQLi > Recordset Paging > Move to Next Page seems to work fine (even though in the dropdown menu it says "Move to Previous," it creates a link that says Next. But when I try to add all the others (First, Previous, and Last), instead of creating 3 new links, it overwrites the Next, no matter where I have the cursor. What am I doing wrong?
What version of the MySQLi extension is installed? Make sure you have the latest version, 1.0.2. If you have a previous version installed, you will need to uninstall it from the extension manager before installing the new one.
also, when adding the new paging control make sure to select the New Link option from the drop down list.
gail.bergan407744
OK perfect. I did in fact have v. 1.0.0 installed, so I uninstalled that and downloaded/installed v. 1.0.2 Now the page works. However, I don't recall ever getting a message that a new version was available - do you send those out?
One suggestion on this server behavior: in the dropdown menu, it always says New Link: Previous Page regardless of whether you are wanting First, Next, Prev, or Last link. It would be less confusing if the menu had all four so you are confident it's going to place the link you want on the page.
Anyway, thanks again for your help.--Gail
I Have logged a bug for this.
