i am having some problem when trying to open an aplliation form i just added to our website.it keeps on bringing an error.please assist me.
Thread began 8/11/2014 10:02 pm by anonymous | Last modified 8/14/2014 8:03 am by Jason Byrnes | 1329 views | 5 replies |
anonymous
Warning: require_once(public_html="http://ngit.org.uk/applicationform.php/") [function.require-once]: failed to open stream: No such file or directory in /websites/123reg/LinuxPackage22/ng/it/_o/ngit.org.uk/public_html/applicationform.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'public_html="http://ngit.org.uk/applicationform.php/"' (include_path='.:/usr/local/php52/share/pear:/usr/local/php52/share/php') in /websites/123reg/LinuxPackage22/ng/it/_o/ngit.org.uk/public_html/applicationform.php on line 1
please send a copy of the page so i can see the code.
anonymous
my domain name is ngit.org.uk and the application form is in my public_html folder.
This is not a vlid path for a require once statement:
<?php require_once(ngit.org.uk/public_html/applicationform.php/local/php55/share/pear/usr/local/php55/share/php); ?>
looks like you are trying to attach a file from the pear library, you should check with the host for the correct path.
your page is also missing the require_once line for the database connection:
<?php require_once('Connections/localhost.php'); ?>
anonymous
mysql_select_db() expects parameter 1 to be string
i keep getting this error when i make those changes.
Warning: mysql_select_db() expects parameter 1 to be string, object given in /websites/123reg/LinuxPackage22/ng/it/_o/ngit.org.uk/public_html/applicationform.php on line 68
Warning: mysql_query() expects parameter 1 to be string, object given in /websites/123reg/LinuxPackage22/ng/it/_o/ngit.org.uk/public_html/applicationform.php on line 70.
this is line 68 and 70
mysql_select_db($myconnection,$register );
$Recordset1 = mysql_query($myconnection, $query_Recordset1 ) or die(mysql_error());
please help.
