Different passwords are logging in to same persons info..Should be two different people
I have two people with the same last name logging in and they are going to the only one person. Put login info in private
in the Security Assist Authenticate user behavior, the Student ID Comparison is set to type3 Integer, but you are passing text in the value.
edit the Authenticate user server behavior to change the data type for the Student ID to text.
I have looked under Authenticate user server behavior. I can't find "data type". for the student ID. I looked on the page at this code Can you please be more specific?
this code (both instances):
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."int"),
should be:
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
It was a session thing..its good now! Thank you Jason!!! always appreciated. :)
