Limit 1
Thread began 8/09/2014 4:39 pm by namon96 | Last modified 8/11/2014 12:17 pm by Jason Byrnes | 626 views | 1 replies |
namon96
Limit 1
Curious as to why when I create a new recordset like
SELECT *
FROM `state`
ORDER BY StateName ASC
The code is changed to
SELECT *
FROM `state`
ORDER BY StateName ASC LIMIT 1
Cheers
It's for efficiency. A recordset should only return as many rows as you are going to use on the page.
by default, you would only use 1 record on the page until a repeat region is added.
The repeat region will change the number of records being returned and change the limit statement.
