orderID Not storing in Session
eCart 6.07
When I add Store Summary in Database the OrderID is not stored as a session variable.
Page attached. . .
eCart 6.07
Page attached. . .
the session name is set to orderID
$WA_sessionName = "orderID";
your trying to write it to the page using a different name:
<?php echo ((isset($_SESSION["fallfest_OrderID"]))?$_SESSION["fallfest_OrderID"]:"") ?>
change that to use the correct session name:
<?php echo ((isset($_SESSION["orderID"]))?$_SESSION["orderID"]:"") ?>
The code was created completely by the Insert Summary wizard, except for the variable name. Will make the change...
