mysqli will not let me advance throught the record set
Thread began 8/08/2014 5:55 am by rpratt89080 | Last modified 8/08/2014 12:52 pm by Jason Byrnes | 2529 views | 14 replies |
rpratt89080
i have a record set and have it in a repeat and all is well. but when i place the paging behavior so i can advance throught the records i get an sql error that is non specific. if i remove the paging and just keep the repeat it works fine but i need to show all my records? any idea why this will not work? I really need the first last next and last behaviors.
rpratt89080
thanks
ok, send a copy of the php file and a dump of the database so I can recreate the problem on my system.
rpratt89080
for you
f
I am not able to use this sql file to recreate the table.
I'll need an export of the table using phpMyAdmin, not sure what GUI Tool you used for the export, but it is not compatible with Sequel Pro
if all else fails, I will need you to upload the page to a server so I can troubleshoot.
rpratt89080
try this
s
change the following code:
$seeds_aor_id->setQuery("SELECT seed.seed_id, seed.seed_full, seed.seed_promo, seed.seed_f_name, seed.seed_l_name, seed.seed_city, seed.seed_state, seed.seed_boat_year, seed.seed_boat_length, seed.seed_date, seed.seed_homeport, seed.seed_homeport_type, seed.seed_member_number, seed.seed_member_exp, co.co_name, co.co_aor_id, boat_make.boat_make FROM seed INNER JOIN co ON seed.seed_co_id = co.co_id INNER JOIN boat_make ON seed.seed_boat_make_id = boat_make.boat_make_id WHERE co.co_aor_id = %s ORDER BY seed.seed_date DESC");
$seeds_aor_id->bindParam("int", "".$_GET['aor_id'] ."", "-1"); //WAQB_Param1
$seeds_aor_id->setQuery("SELECT seed.seed_id, seed.seed_full, seed.seed_promo, seed.seed_f_name, seed.seed_l_name, seed.seed_city, seed.seed_state, seed.seed_boat_year, seed.seed_boat_length, seed.seed_date, seed.seed_homeport, seed.seed_homeport_type, seed.seed_member_number, seed.seed_member_exp, co.co_name, co.co_aor_id, boat_make.boat_make FROM seed INNER JOIN co ON seed.seed_co_id = co.co_id INNER JOIN boat_make ON seed.seed_boat_make_id = boat_make.boat_make_id WHERE co.co_aor_id = ? ORDER BY seed.seed_date DESC");
$seeds_aor_id->bindParam("i", "".$_GET['aor_id'] ."", "-1"); //WAQB_Param1
make sure you have the latest MySQLi version installed, 1.0.2, if you have a previous version, uninstall it from the extension manager before installing the new one.
rpratt89080
still no love?
s
index.php
rpratt89080
got it.
I had to rebuild all server behaviors to get it to work, not just the one you helped me with.
Thanks!
