When use Import Web Page(s) I get this error: TypeError: MM SiteToolsActivate function
Design Extender 1.1.9
DW CS5
OS: Win7
I've removed the cache and reset the workspace but I get this error every time.
Cheers,
Doug
DW CS5
OS: Win7
Cheers,
Doug
Try uninstalling Design Extender from the extension manager, then reinstall it.
when you open Dreamweaver, it should launch the WebAssist installer. if not, open a php page to trigger it.
when the WebAssist installer completes the installation, make sure to restart DW.
Jason,
Gave that a go already and the installer triggered but I still get the error.
I had an earlier version of Design Extender, so I updated to 1.1.9 and thought that would fix the problem - no luck.
I cleared the cache file and reset the DW workspace - no luck.
The other WA extensions I have installed, if relevant, are:
DataAssist 2.1.0
Universal Email 4.0.1
SecurityAssist 2.0.5
Cheers,
Doug
Universal Email 4.0.1 and SecurityAssist 2.0.5 are a part of data Bridge, you should not have those installed as stand alones.
uninstall all extensions, the reinstall only Design Extender and Data Bridge, having UE and Security Assist installed is causing a conflict.
I'll give it a go. Cheers
It worked but now I don't have access to Universal Email and SecurityAssist. I removed them as instructed but, I don't have Data Bridge, I do have Data Assist. Is it okay to re-install Universal Email and SecurityAssist
you would need to uninstall all extensions, then install the older extensions, security assist, Universal Email and Data Assist, then install Design Extender last.
Ok I have followed the above several times now even resorting to manually removing any remainder files or folders from all webassist extensions. Final time installed the following extensions in date order. Oldest being the first installed and the newest ie Design Extender 1.2.0 being the last.
At each installation point after completing the serial number and activating, resetting the the default classic view then quiting DW and deleting the winfilecache each time. Slowly error messages disappear as each extension is installed, except for Design Extender when attempting to use Site Import
On Windows 7 Pro 64bit / DW CS4 using
Extensions installed in date order:
CSS Form Builder 1.0.2
DataAssist 2.1.0
eCart 5.0.7
And the errors I receive are:
At line 22 of file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS4\Configuration|Floaters\WA_SiteTools_ProgressV2.js":theDOM has no properties
* The following Javascript error(s) occurred:
Unable to open script file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS4\Configuration\WA_Installer\Library2\WA_Configuration.js" (error 3).
Site Import
Panel 282 could not be created. Removing it from the list.
Panel 285 could not be created. Removing it from the list.
Error in button onClick:
TypeError: MM.SiteToolsActivate is not a function
Now considering at one time there were far more extensions installed before Design Extender came along with far less if none at all issues. The only ones that I know regularly work in design extender are Google Maps and the Social buttons.
Any suggestions on this to a fix, as this is the first time I have attempted to use the Site Import section of design extender which has resulted in the above.
Also note that the error marked with *. If I create a folder called Library2 and duplicate the contents of the folder called Library those related errors go away???
To be honest pulling my hair out with this. I put up with the first 2 errors for a while but now its taking the P***!
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
