Registration Form with php include
Thread began 8/07/2014 1:21 am by Bello | Last modified 8/07/2014 8:43 pm by Jason Byrnes | 1256 views | 5 replies |
Bello
hello, please i have a registration page generated by security assist and with the structure of my site i am to include it into a page that loads multiple php files when u append its url (e.g: trial.php?key=registration)..here is my script below..the issue is whenever the registration page is included..it doesnt submit the form not validate the form...it redirects to the php file that loads the page(i.e trial.php)...any help will be appreciated as i am on a hot sit now thanks.
The page that loads other php files:
<head>
</head>
<body>
header...Goes here
$key=$_GET['key'];
if($key=='home')
include('home.php'); // Home page
else if($key=='login')
include('login.php'); // Login page
else if($key=='registration')
include('registration.php'); // Terms page
else
include('users.php'); // Users Gateway
<br />
<br />
footer...Goes here
</body>
</html>
My registration is the normal registration page generated by webassist...i havent tested the logins and update pages but sure i know they might react in similar patter..thanks
Dont use include() to add the registration page:
That is not a very good way to add a page to another as the php code on the registration page above the doctype will now be in the body of the trial page, and it will also include multiple head and body sections.
Instead, Use framework Builder Dynamic Plugins
Open the bindings panel. Click the plus button and create a new URL variable binding, name it key
Then go to WebAssist -> Framework Builder -> Plug-in -> Insert Dynamic Plug-in
for the trigger variable, select the key URL variable. For the Plugin source, select the registration page, and the variable value use reg
Bello
Wow...thanks....didnt know i had such a tool at hand...thanks a tone of a million...you reli made my day..pls guys dont sell your company like InterAKT....
you're welcome.
Bello
ok well ..it solved the issue to an extent...but the main issue remains unsolved...i did as commanded..but on clicking submit, the regisration page goes back to the "trial.php" without inserting or even validating the page..i attached the two files for you to see..i can also attach all the files if requested..
here is the scenario: i typed: - "page-loader.php?mod=email-here" - this is the registration page...and after clicking submit button..it goes back to "page-loader.php" without validating or inserting the form in the database...and this happens only of included in another page either by include or by webassist framework.
page-loader.php
registration.php
start-here-1.php
Since the page is being loaded with a URL variable as the trigger, you will need to modify the action of the registration form so that it passes the URL variable on post.
change the action:
action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>"
action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlentities($_SERVER["QUERY_STRING"], ENT_QUOTES):""; ?>"
