MySQLi ->execute(); generate Error 500
Thread began 8/06/2014 9:48 am by David Mancuso | Last modified 8/11/2014 8:24 am by Jason Byrnes | 2811 views | 5 replies |
David Mancuso
Hi, in local server, I don't have any problem with MySQLi query. But if I upload all files on server (php version 5.3.24), all page where the are a MySQLi query generate Error 500. I changed correctly configuration file. All data are right.
If I remove namequery->execute(); I don't have any error 500.
David Mancuso
Thank you!
The 500 error is generic error hosts will use to mask the actual error that is occurring.
normally, turning on error reporting:
error_reporting(E_ALL);
should show the true error, I added that code at line but it is not showing the true error. Sometimes hosts will set the server so that the error reporting cannot be changed using PHP code, looks like that is the case with this host. You will need to contact the host to have them look into the error logs to find the true error that is occurring. once i know what the true error says i can troubleshoot.
one this I see is that the connection, query and the table you are querying all use the same name:
test
you should use unique names for the connection and recordset.
David Mancuso
Thank you for you preciuos support. I have updated the PHP version to 5.4 and the problem was solved.
Glad to hear it is working.
