MySQLi insert record not showing date form field in dynamic column bindings
I'm trying to add an insert record form to a page on my website. All of the fields in my form show up in the dynamic data bindings except for the date field (see attached screenshot).
<?php require_once('Connections/local.php'); ?>
<?php require_once('Connections/local_i.php'); ?>
<?php require_once("webassist/database_management/wa_appbuilder_php.php"); ?>
<?php require_once('webassist/mysqli/queryobj.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
$room = new WA_MySQLi_RS("room",$local_i,0);
$room->setQuery("SELECT kids_program_room.* FROM kids_program_room");
$room->execute();
$position = new WA_MySQLi_RS("position",$local_i,0);
$position->setQuery("SELECT kids_program_position.* FROM kids_program_position");
$position->execute();
$time = new WA_MySQLi_RS("time",$local_i,0);
$time->setQuery("SELECT kids_program_time.* FROM kids_program_time");
$time->execute();?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
if ((((isset($_POST["submit"]))?$_POST["submit"]:"") != "")) {
$InsertQuery = new WA_MySQLi_Query($local_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "kids_program_shifts";
$InsertQuery->bindColumn("kids_program_team_id", "i", "2", "WA_DEFAULT");
$InsertQuery->bindColumn("kids_program_room", "s", "".((isset($_POST["room"]))?$_POST["room"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("kids_program_time", "s", "".((isset($_POST["time"]))?$_POST["time"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("kids_program_volunteer", "i", "".$row_WADApcms2_users['UserID'] ."", "WA_DEFAULT");
$InsertQuery->bindColumn("kids_program_position", "s", "".((isset($_POST["position"]))?$_POST["position"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("recurring", "c", "".((isset($_POST["recurring"]))?$_POST["recurring"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
$ParamUserID_WADApcms2_users = "-1";
if (isset($_GET['UserID'])) {
$ParamUserID_WADApcms2_users = $_GET['UserID'];
mysql_select_db($database_local, $local);
$query_WADApcms2_users = sprintf("SELECT UserID, UserEmail, UserFirstName, UserLastName, UserCity, UserState, UserZip, UserPhone, UserCountry, UserGender, UserAddress, UserAddress2, UserDOB, SmallGroup FROM pcms2_users WHERE UserID = %s", GetSQLValueString($ParamUserID_WADApcms2_users, "int"));
$WADApcms2_users = mysql_query($query_WADApcms2_users, $local) or die(mysql_error());
$row_WADApcms2_users = mysql_fetch_assoc($WADApcms2_users);
$totalRows_WADApcms2_users = mysql_num_rows($WADApcms2_users);?>
$KidsProgramShifts = new WA_MySQLi_RS("KidsProgramShifts",$local_i,1);
$KidsProgramShifts->setQuery("SELECT kids_program_shifts.date, kids_program_shifts.recurring FROM kids_program_shifts");
$KidsProgramShifts->execute();
// WA Application Builder Delete
if (isset($_POST["Delete"]) || isset($_POST["Delete_x"])) // Trigger
$WA_connection = $local;
$WA_table = "pcms2_users";
$WA_redirectURL = "pcms2_users_results.php?UserID=".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "UserID";
$WA_columnTypesStr = "',none,''";
$WA_fieldValuesStr = "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
$WA_comparisonStr = "=";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_local;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<script src="webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<link href="webassist/forms/fd_basic_default.css" rel="stylesheet" type="text/css">
<link href="webassist/forms/dataassist_button.css" rel="stylesheet" type="text/css" />
<style>
/* Details page CSS */
form.DetailsPage {
width: auto;
.black_overlay{
display: none;
position: absolute;
top: 0%;
left: 0%;
width: 100%;
height: 100%;
background-color: black;
z-index:1001;
-moz-opacity: 0.8;
opacity:.80;
filter: alpha(opacity=80);
.messageContainer {
display: none;
position: absolute;
top:0;
width: 100%;
z-index:1002;
text-align:center;
height:100%;
#position: relative;
overflow: hidden;
.messageWrapper {
#position: absolute;
#top: 50%;
display: table-cell;
vertical-align: middle;
.messageContent {
background-color:white;
display: inline-block;
padding: 16px;
border: 16px solid grey;
z-index:1002;
overflow: auto;
margin: auto;
#top: -50%;
}</style>
</head>
<body>
<div id="Details_Basic_Default_ProgressWrapper">
<form class="DetailsPage Basic_Default" id="Details_Basic_Default" name="Details_Basic_Default" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
<fieldset class="Basic_Default" id="Details">
<legend class="groupHeader">Details</legend>
<div>
<a name="top"></a>
<?php if ($totalRows_WADApcms2_users > 0) { // Show if recordset not empty ?>
<div id="WADADetails">
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0" width="100%">
<tr>
<td class="DetailsSublabel">User ID:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserID']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Email:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserEmail']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">First Name:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserFirstName']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Last Name:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserLastName']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">City:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserCity']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">State:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserState']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Zip Code:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserZip']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Phone:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserPhone']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Country:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserCountry']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Gender:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserGender']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Address:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserAddress']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Address2:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['UserAddress2']); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Date of Birth:</td>
<td class="DetailsPage"><?php echo(($row_WADApcms2_users['UserDOB'])?date('n/d/Y',strtotime($row_WADApcms2_users['UserDOB'])):''); ?></td>
</tr>
<tr>
<td class="DetailsSublabel">Small Group:</td>
<td class="DetailsPage"><?php echo($row_WADApcms2_users['SmallGroup']); ?></td>
</tr>
<tr>
<td colspan="2"> </td>
</tr>
</table>
<hr/>
</div>
<?php } // Show if recordset not empty ?>
<?php if ($totalRows_WADApcms2_users == 0) { // Show if recordset empty ?>
<div>
<div>This record has been removed.</div>
</div>
<hr/>
<?php } // Show if recordset empty ?>
</div>
<span class="buttonFieldGroup" >
<div>
<input type="button" value="Update" class="formButton unstyled" id="Update" name="Update" onClick="document.location.href = 'pcms2_users_update.php?UserID=<?php echo($row_WADApcms2_users["UserID"]); ?>
<?php echo(isset($_GET["pageNum_WADApcms2_users"])?"&pageNum_WADApcms2_users=".intval($_GET["pageNum_WADApcms2_users"]):""); ?>';" />
<table border="0" cellpadding="0" cellspacing="0">
<tr>
<td><input type="button" value="Top" class="formButton unstyled" id="Top" name="Top" onclick="window.location.hash='top';" /></td>
<td> </td>
<td><input type="button" value="Delete" class="formButton unstyled" id="DeleteConfirm" name="DeleteConfirm" onclick="document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';" /></td>
<td><input type="button" value="Back To Results" class="formButton unstyled" id="BackToResults" name="BackToResults" onclick="document.location.href = 'pcms2_users_results.php<?php echo(isset($_GET["pageNum_WADApcms2_users"])?"?pageNum_WADApcms2_users=".intval($_GET["pageNum_WADApcms2_users"]):""); ?>';" /></td>
</tr>
</table>
</div></span>
</fieldset>
</form></div><div id="Details_Basic_Default_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('Details_Basic_Default', 'Details_Basic_Default_ProgressMessageWrapper', WADFP_Theme_Options['BigSpin:Slate']);
</script>
<div id="Details_Basic_Default_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="webassist/progress_bar/images/slate-largespin.gif" alt="" title="" style="vertical-align:middle;" /> Please wait</p>
</div>
</div>
<div class="black_overlay" id="deleteBox"></div>
<div class="messageContainer" id="deleteMessage">
<div class="messageWrapper">
<form class="Basic_Default" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>" style="width:auto;">
<input type="hidden" name="WADADeleteRecordID" id="WADADeleteRecordID" value="<?php echo($row_WADApcms2_users["UserID"]); ?>" />
<div class="messageContent">
This will permanently remove the record from your database.<br/>
This action cannot be undone.<br/><br/>
<input type="submit" value="Delete" class="formButton unstyled" id="Delete" name="Delete" />
<input type="button" value="Cancel" class="formButton unstyled" id="Cancel" name="Cancel" onclick="document.getElementById('deleteBox').style.display = 'none';document.getElementById('deleteMessage').style.display = 'none';" />
</div>
</form>
</div>
</div>
<form>
<select name="room" id="room">
while(!$room->atEnd()) { //dyn select
<option value="<?php echo($room->getColumnVal("id")); ?>"><?php echo($room->getColumnVal("room")); ?></option>
$room->moveNext();
} //dyn select
$room->moveFirst();
</select>
<select name="time" id="time">
while(!$time->atEnd()) { //dyn select
<option value="<?php echo($time->getColumnVal("id")); ?>"><?php echo($time->getColumnVal("time")); ?></option>
$time->moveNext();
} //dyn select
$time->moveFirst();
</select>
</select>
<input type="hidden" value="<?php echo $row_WADApcms2_users['UserID']; ?>">
<select name="position" id="position">
while(!$position->atEnd()) { //dyn select
<option value="<?php echo($position->getColumnVal("id")); ?>"><?php echo($position->getColumnVal("position")); ?></option>
$position->moveNext();
} //dyn select
$position->moveFirst();
</select>
<input type="date" name="date">
<input type="checkbox" name="recurring">
<input type="submit" name="submit">
</form>
</body>
</html>
mysql_free_result($WADApcms2_users);
