Search Results "Next Page" button not showing results
Thread began 8/06/2014 7:42 am by Nick | Last modified 7/24/2015 5:11 pm by Ray Borduin | 3175 views | 8 replies |
Nick
For some reason, the first page of search results displays perfectly. However, I know for a fact that there are over 3400 entries in the table, and when I click the "Next Page" button, it displays a "No Results Found" page. I noticed that in the url, the line that dictates the number of table rows is set to 0, like this: totalRows_WADAtblHorse=0. I snooped around a little in the PHP code but it was beyond me and I couldn't find a fix. Can anyone help?
Thanks in advance,
Nick
Links: http://www.winnerdigital.net/databridge
send a copy of the tblHorse_results.php page please.
Nick
Thank you for your prompt reply, sending it in the attachments.
I Dont see a problem in the code, I'll need to troubleshoot directly, see the private message section.
Nick
Sure thing:
i updated the results page to fix the probelm, this peace of code was before the recordset:
$currentPage = $_SERVER["PHP_SELF"];
$queryString_WADAtblHorse = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAtblHorse") == false &&
stristr($param, "totalRows_WADAtblHorse") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAtblHorse = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAtblHorse = sprintf("&totalRows_WADAtblHorse=%d%s", $totalRows_WADAtblHorse, $queryString_WADAtblHorse);
I moved it to be after the recordset.
Nick
Fixed!
Thank you so much, worked like a charm!
you're welcome.
Charles
This post was helpful to me as I encountered the same problem(a year later than Nick) and moving the chunk of code you identified fixed it. Thank you.
Meanwhile, it seems that DA for Product Admin needs to be fixed to put that code in the right place when it generates the products_results page the first time. Maybe something to put on your list for next release? Just a thought . . .
