redirect insert page to newly created detail page
Thread began 8/04/2014 6:35 pm by Mark | Last modified 8/08/2014 2:02 pm by Jason Byrnes | 1258 views | 11 replies |
Mark
How do I code the redirect on my insert page to go to the details page of the record I just created?
If you are using the latest version of Data Bridge, use [Insert_ID] to refer to the inserted ID.
so set the redirect URL to:
page.php?id=[Insert_ID]
the code will automatically replace [Insert_ID] with the ID of the inserted record.
Mark
For some reason, that's not working. It's coming back with an ID of "0". Is it because I have data going to two separate tables? Here is the code (in the private message - which Ray helped me set up).
In the FAQs table, is the ID column set to auto increment?
the ID column will need to be an auto increment column for the redirect to work properly.
Mark
No, its not. It's set to get the same ID as the "toys" table since they need to be locked. Ray had me delete the re-direct from the toys table since the FAQ insert came after it. How can I make this work?
ok, so the actual question here is: how to use 2 insert behaviors and set the redirect in the second one to use the session created by the first.
that you need to hand code, the session created by the first insert is named WADA_Insert_toys. so edit the redirect:
$WA_redirectURL = "../pages/halloween2.php?productID=[Insert_ID]";
$WA_redirectURL = "../pages/halloween2.php?productID=".$_SESSION['WADA_Insert_toys'].";
Mark
Thanks Jason, but there seems to be a slight problem with that code. The page won't display now. I think it has either one too many or one too few quote marks in it.
sorry, you're right, there is a missing quote, it should be:
$WA_redirectURL = "../pages/halloween2.php?productID=".$_SESSION['WADA_Insert_toys']."';
Mark
Something still isn't right. I think the single and double quotes aren't matching.
OK, I got it. The single quote at the end of the string needed to be double.
ghaa, i need more coffee. . . or maybe a better shift key. it should be a double quote at the end:
$WA_redirectURL = "../pages/halloween2.php?productID=".$_SESSION['WADA_Insert_toys']."";
