Image upload troubleshooting
Thread began 8/04/2014 4:31 pm by Justin@AdventDesign | Last modified 8/12/2014 12:53 pm by Justin@AdventDesign | 1243 views | 16 replies |
Justin@AdventDesign
I've been using webassist extensions for many years and am very familiar with the file manipulation upload wizard. I need help trouble shooting an image upload problem that has me totally stumped. When modifying an existing record, I can't get the page to upload a new image. The insert page uploads just fine.
I've made sure the enctype="multipart/formdata" is in the form tag.
I've compared the insert to the upload page.
It doesn't appear to be a file size issue (Even extremely small jpgs fail to upload.
It's not a permissions problem with the target folder (as it works just fine on the insert page).
I've inserted the error reporting code as indicated on other threads.
I've attached the problem page (incidently, the other two table data assist forms fail to work on the upload pages as well), as well as the working insert page. I'll post FTP information in a private message in case you want to look at it directly on the server.
so lets use the insert page to troubleshoot.
to troubleshoot upload issues:
1) turn on error reporting, add this code at line 1:
<?php error_reporting(E_ALL); ini_set('display_errors','on'); ?>
2) add debug info to the page body. open the bindings panel, expand the WA Uploaded files Global status group and add the debug info binding to the page.
3) prevent the insert from redirecting:
change:
$WA_redirectURL = "tbNews_results.php";
$WA_redirectURL = "";
4) write the files array to the page:
if(isset($_FILES)) {
var_dump($_FILES);
post back the results after trying an upload.
Justin@AdventDesign
Done. Here's what I get on the insert page:
Status object: WA_UploadResult1
statusCode : 1
errorMessage :
clientFileName : BanksWhitePigeon2014Aerial_Facilities-Panel.jpg
fileExtension : jpg
serverFileName : news47.jpg
serverSimpleFileName : news47
serverDirectory : /home/elkhartj/public_html/sitecontrol/../cmsimages/full/
contentType : image/jpeg
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : 73488
isImage : 1
imageWidth : 866
imageHeight : 388
WA_UploadResult1_1:
fileExtension : jpg
fileSize : 73488
imageWidth : 866
imageHeight : 388
isImage : 1
fileWasSkipped :
fileWasRenamed :
statusCode : 1
WA_UploadResult1_2:
fileExtension : jpg
serverDirectory : /home/elkhartj/public_html/sitecontrol/../cmsimages/detail/
fileSize : 49973
imageWidth : 750
imageHeight : 336
isImage : 1
fileWasSkipped :
fileWasRenamed :
statusCode : 1
WA_UploadResult1_3:
fileExtension : jpg
serverDirectory : /home/elkhartj/public_html/sitecontrol/../cmsimages/mini/
fileSize : 3750
imageWidth : 150
imageHeight : 67
isImage : 1
fileWasSkipped :
fileWasRenamed :
statusCode : 1
array(1) { ["photo"]=> array(5) { ["name"]=> string(47) "BanksWhitePigeon2014Aerial_Facilities-Panel.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(14) "/tmp/php3gARgR" ["error"]=> int(0) ["size"]=> int(204305) } }
Justin@AdventDesign
That's a little different than my error reporting set up on the upload page. Should I do exactly the same to the upload page?
this in the debug info:
statusCode : 1
and:
means the file is being uploaded. the upload is working.
Justin@AdventDesign
Here's what I get from the upload page using the same error reporting set up:
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName : news46.jpg
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
WA_UploadResult1_2:
clientFileName :
fileExtension :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
array(0) { }
I just tried the update page and got the following in the debug info:
statusCode : 1
errorMessage :
clientFileName : Sapphire Square.gif
fileExtension : jpg
serverFileName : Sapphire Square.jpg
serverSimpleFileName : Sapphire Square
fileWasSkipped :
fileWasRenamed :
fileSize : 1308
isImage : 1
imageWidth : 48
imageHeight : 48
WA_UploadResult1_1:
fileExtension : jpg
fileSize : 1308
imageWidth : 48
imageHeight : 48
isImage : 1
fileWasSkipped :
fileWasRenamed :
statusCode : 1
WA_UploadResult1_2:
fileExtension : jpg
fileSize : 1308
imageWidth : 48
imageHeight : 48
isImage : 1
fileWasSkipped :
fileWasRenamed :
statusCode : 1
array(1) { ["photoupdate"]=> array(5) { ["name"]=> string(19) "Sapphire Square.gif" ["type"]=> string(9) "image/gif" ["tmp_name"]=> string(14) "/tmp/phpQImSTw" ["error"]=> int(0) ["size"]=> int(2187) } }
update seams to be working.
Justin@AdventDesign
So why would I be getting different results? I've tried both on my local test server and on the remote server. I've tried several different jpgs. I've tried a GIF. No matter what I do, the file fails to upload. Last report was this:
statusCode : 0
clientFileName :
fileExtension :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
WA_UploadResult1_2:
clientFileName :
fileExtension :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
array(0) { }
Without being able to reproduce, I cant really say.
what OS are you using?
and Browser? could be a browser issue.
Justin@AdventDesign
Browser issue hadn't occurred to me but that appears to be the culprit. Using Chrome 36 on Mac. Safari 5.1 appears to work OK. Any direction on troubleshooting the browser issue? My only guess would be some new overzealous security feature that isn't allowing the browser to upload a file?
I should say, I use chrome all the time and have for years and never run into this before.
