Migrating to CKFinder
More and more clients have problems with invisible thumbnails in the file manager. Is it a long time until you migrate to CKFinder or it is possible to have this fixed in some other way?
See attached picture
Regards
Rune
Regards
Rune
We plan to migrate to CKFinder in the next upgrade to Data Bridge, we don't have a fixed time frame for when that will be available though.
In reality, there is not really another way to fix the blank thumbnails.
If the server has Denial of service protection in place that will prevent synchronous php calls, would it be an alternative to change provider of web hosting? Some of my clients that use another web host does not seem to have this problem. How do I know if the server has Denial of service protection in place or not?
Regards
Rune
Sure, changing hosting may be an alternative.
if you want to know if the host uses Denial or Service protection, you should ask them.
