multiple tables for details page
Thread began 8/01/2014 2:54 am by Mark | Last modified 8/01/2014 5:28 pm by Jason Byrnes | 655 views | 7 replies |
Mark
Ray helped me out today during a paid support session with adding data from two tables on a details page. He joined the "toys" table with the "MIT" table to bring in the "MIT_Link" with this code:
$query_rsDetails = sprintf("SELECT toys.*, MIT_Link FROM toys LEFT OUTER JOIN MIT ON MIT.MIT_ID = toys.MIT_ID WHERE productID = %s", GetSQLValueString($colname_rsDetails, "int"));
Now, I need to add data from two other tables - a "dc_Link" from a table called "dcAdaptor" and a "footpad_Link" from a table called "footpad". I cannot figure out how to incorporate those new elements in the code.
You need to add additional joins to the SQL.
I Would need to know the table structures and how they relate to offer any more advice.
Mark
OK, the MIT, dcAdaptor, and footpad tables all have just two columns - the unique ID and the Link ("MIT_ID" and "MIT_Link", "dcAdaptor_ID" and "dcAdaptor_Link" etc.) The main "toys" product table contains a column for each of the unique IDs. The common element between the tables is therefore the unique ID. Does that tell you enough?
"The main "toys" product table contains a column for each of the unique IDs"
what are the column names?
i need the exact names of the columns. . .
Mark
The ID for the MIT table is called "MIT_ID". The ID for the dcAdaptor table is called "dcAdaptor_ID". The ID for the footpad table is called "footpad_ID".
The column name for MIT in the toys table is called "MIT_ID". The column name for dcAdaptor in the toys table is called "dcAdaptor_ID". The column name for footpad in the toys table is called "footpad_ID".
OK, so the origianl SQL without the where clause is:
FROM toys
edit that to:
SELECT toys.*, MIT_Link, dcAdaptor.*, footpad.*
FROM toys
LEFT OUTER JOIN dcAdaptor ON dcAdaptor.dcAdaptor_ID = toys.dcAdaptor_ID
LEFT OUTER JOIN footpad ON footpad.footpad_ID = toys.footpad_ID
leave the where clause untouched.
Mark
Thanks so much Jason!
you're welcome.
