Syntax Error on Validate form
Thread began 7/31/2014 2:59 pm by rgolab68503 | Last modified 8/01/2014 11:23 am by Jason Byrnes | 2723 views | 13 replies |
rgolab68503
Hi Jason,
i just went through the tutorial http://www.webassist.com/tutorials/Double-opt-in-registration. Great tutorial.
For some reason however i am now getting a syntax error on line 9. I have removed the temporary DAT in the AppData\Roaming\Adobe\Dreamweaver CS6\en_US\Configuration and removed notes folders in Dreamweaver as you had instructed before. Same Java error.
I should note that I started after the completion of the tutorial having an error on line 2
"wa_randompassword.php not found". Web assisist didn't create the file but i found in a recent post you had supplied the file so i simply copied it to the correct folder and it got past that step.
I have even tried saving my registration page as a backup and then recreated the registration page using security assist again only for the same error to come up. I checked this code with another page and it is identical but not showing as a syntax error on that page so needless to say i am puzzled.
Any ideas?
line 7 - 8:
<?php require_once( "../webassist/security_assist/helper_php.php" );
is missing a closing php tag:
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
rgolab68503
Hi Jason,
Already tried that. :( When I do that I don't get an error message but I do get a blank page.
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
rgolab68503
I do like to challenge you Jason. Error reporting on and still a blank page.
The blank page may have started after I dropped in the wa_randompassword.php file. It's the first place it goes when the page loads so I attached it just in case it gives a clue.
rgolab68503
info below.
See PM
rgolab68503
see below - this is supposed to work with your IP
not able to connect
