Just installed - throwing errors
Hi Jason,
Just installed mysqli and I'm getting javascript errors, I've deleted the cache file but it still happens, attached is the error message
cheers
Norman
Hi Jason,
cheers
Norman
try uninstalling eCart then installing it again.
Thanks again for your outstanding support Jason,
Followed your instructions, all's fine now
Cheers
Hi Jason
Now I'm repeatedly, being asked to activate DataBridge?
This usually happens if you have some sort of virtual network adapter that changes the MAC Address of the physical connection. Normally part of a VPN package fro creating virtual private networks.
Open the DOS Command Prompt as admin, and type:
ipconfig /all
to see all of the systems network connections, do anything have "virtual" in the description?
that will be the one causing the activation conflict.
Thanks Jason,
Loaded DW this morning and all is well.
There is VM software on this computer, perhaps that might have caused the hassle
Cheers
Norman
Activation problem happening again, how do resolve this, don't really want to remove my vm ware
Cheers
Norman
