Deleting records database
Thread began 7/29/2014 4:21 pm by gail.bergan407744 | Last modified 7/31/2014 11:28 am by Jason Byrnes | 1161 views | 6 replies |
gail.bergan407744
I'm building a page for our admins to delete member records from our database. I used your Delete Record server behavior, but I'm getting an error message on lines 49-50 on the attached file. Can you spot what is wrong?
what is the full text of the error message?
To troubleshoot an error, i need to know what the error says. . .
this code:
if (isset(".(isset($_GET['user_id'])?$_GET['user_id']:"")  .")) {
$colname_getUser_i = ".(isset($_GET['user_id'])?$_GET['user_id']:"") .";
should be:
if (isset($_GET['user_id'])) {
$colname_getUser_i = $_GET['user_id'];
gail.bergan407744
Erroneous code
I'm glad you received the file, I was beginning to think I forgot to attach it.
That incorrect bit of code is not something I manually entered - how do I check for this in the future? I'm not knowledgeable enough to hand-code things or spot errors.
when you created the recordset, you entered the run time value for the filter variable incorrectly, that caused the code to be generated incorrectly.
gail.bergan407744
I'm not even sure where to set a run time value for a filter variable - where do I do that? Now, even with the new code you sent, I'm getting a different error message. Please see attached file. The message is:
Warning: mysql_select_db() expects parameter 2 to be resource, object given in C:\wamp\www\2010 new site\delete_user2.php on line 53
Warning: mysql_query() expects parameter 2 to be resource, object given in C:\wamp\www\2010 new site\delete_user2.php on line 55
you would set the run time value for the filter in the filter section of the recordset.
the recordset that you are using on this page is a standard MySQL recordset, not one from the MySQLi server behaviors, but you have selected to use the MySQLi connection.
you need to create a standard connection to use with the standard recordset or remove the recordset and recreate it as a MySQLi recordset.
