Fedex Error
checkout page to confrim page and got this error
Fatal error: Call to undefined function curl_init() in C:\inetpub\wwwroot\storesample\WA_eCart\WA_eCart_FedEx_PHP.php on line 140
I have included fedex script and globals page
thank you
thank you
The curl_init() function is a PHP function.
To use the curl_init() function, you will need to modify your php.ini file.
find the following line:
;extension=php_curl.dll
and remove the comment:
make sure to restart you web server after making this change, also check that the php_curl.dll file is in the PHP extensions directory.
