Dreamweaver line 383 file \Library\WA_Configuration js: toCheck properties
Thread began 7/15/2014 7:47 am by Art | Last modified 7/15/2014 8:55 am by Jason Byrnes | 1916 views | 10 replies |
Art
I'm getting the following errors when I open Dreamweaver.
"At line 383 of file ...\FormBuilder\Library\WA_Configuration.js": toCheck has no properties"
AND THEN
At line 12 of file ...\LayoutManager\shared.js": wa is not defined
eCart 6 - DW 6
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
Art
I had already done that a couple times. I've tried uninstalling ecart and CSS Form Builder, dumping cache file and reinstalling them.
This is all on a pretty fresh re-install of the Adobe Suite 6.
When reporting a problem, it is always a good idea to report any troubleshooting steps you have already taken, that way I wont have you repeat them if I know you have already tried them.
What extensions including the version numbers are installed?
Art
CSS FORM BUILDER 2.0.1
DATAASSIST 2.1.0
DYNAMIC CONNECTION 1.0.0
eCart 6.0.7
Form Toolkit 1.0.0
Framework Builder 1.0.2
SecurityAssist 1.1.9
The stand alone extensions:
DATAASSIST 2.1.0
Form Toolkit 1.0.0
are not compatible with Dreamweaver CS6.
To continue using those versions, you will need to use a previous version version of Dreamweaver.
If you wish to use those extensions in DW CS6, you will need to upgrade to Data Bridge.
Art
OK, that explains all the issues I've had the last year and a half.
Art
Not sure if this is related or not but I tried running the Security Assist Login Wizard and got this error:
At line 1635 of file "C:\...\SecurityAssist\SecurityAssist_Objects.js": sbObj.Nodes no properties
like I said in my previous reply, SecurityAssist 1.1.9 is not compatible with Dreamweaver CS6.
Art
I posted it before I saw your post.
