MySQLi recordset and special chars
Thread began 7/15/2014 4:40 am by info298111 | Last modified 7/16/2014 7:36 am by info298111 | 2616 views | 6 replies |
info298111
I have a page using special characters from a database. Dbase and page is UTF-8. With traditional recordset the special character is shown correct, with MySQQLi recordset it is NOT shown correct. Page is located at: http://sopkafee-makkum.nl/entree.php.
Pse advice
info298111
Link
Reply is in private msg
the character:
û
is not a UTF8 character.
The standard DW connection does not set the character set, so uses the default latin1 character set.
in the Connections/sopkafee_i.php file, i commented the charset line:
//$sopkafee_i->set_charset('utf8');
to use the default charset to fix the problem.
info298111
  the character:
û
all you need to do is not set the character set in the connection.
in the connection settings leave the character set at default.
info298111
Ah, got it now. Thanks
