Pull database data into a style tag?
Thread began 7/09/2014 11:27 am by Jared Lui | Last modified 7/09/2014 1:26 pm by Jason Byrnes | 326 views | 3 replies |
Jared Lui
Anyone know how or if it's possible to bind a recordset data into a CSS or inline in a tag? Something along the lines of this (which does not work)
<div style="background-color:#<?php echo $row_store['MenuColor']; ?>"> TEXT HERE</div>
I have tried using this in the php page and in a separate style sheet.
I do not want to have to create a separate CSS for each user and would rather just add a few fields in the Users table that can output the styles but I don't know of any other way to do this.
thoughts?
this should work:
as long as the recordset is returning the proper result, double check that the recordset is retuning the correct result, you can add the recordset eco in the div to see what it is retuning:
<div style="background-color:#<?php echo $row_store['MenuColor']; ?>"> |<?php echo $row_store['MenuColor']; ?>|TEXT HERE</div>
Jared Lui
DOH! I had changed an ID field earlier today and forgot to make the change to my session.
Guess my grandma was right, you play with it too long and you might go blind.
Glad to hear you found the problem.
