Fetch_assoc()
Thread began 7/05/2014 2:13 pm by msummers194171 | Last modified 7/07/2014 9:01 am by Jason Byrnes | 2575 views | 3 replies |
msummers194171
Fetch_assoc()
How do I do this now? I want to grab a recordset, which I have done, and then drop some dynamic content from that recordset within a repeat region - like this -
while(!$rsQuoteSnippet->atEnd()) {
<p><?php echo $rsQuoteSnippet['quotes_snip']; ?></p>
$rsQuoteSnippet->moveNext();
I'm being told "Fatal error: Cannot use object of type WA_MySQLi_RS as array in /var/www/GWS/TMPcxhxh8.php on line 27"
Use the bindings panel to add the recordset binding to the page.
instead of:
to write a recordset value, the syntax would be:
<?php echo($rsQuoteSnippet->getColumnVal("quotes_snip")); ?>
if you use the bindings panel, it will write the correct syntax for you.
msummers194171
How silly! I've done this manually for so long I completely forgot about the "UI" way of doing things!
Thanks, Jason!
you're welcome.
