email plugin page not sending email
Thread began 6/26/2014 2:09 pm by The Flying Fox | Last modified 7/17/2014 3:42 pm by Jason Byrnes | 2233 views | 5 replies |
The Flying Fox
My contact form plug in does not seem to work.
I have been using plug ins for a short time but I cannot get my contact plug in to send an email.
It re directs to the correct page but no email is sent.
can you please point me in the right direction.
Thank you
Andy
does the contact form work if it is not used a s a plugin?
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
The Flying Fox
Hi Jason,
The form works independently as a stand alone form but not as a plugin, that is what I cannot work out..
I use i Page and so far have not had to add any info for email usage. the only change i have ever made is the character set which i have changed to utf8 field which I don't believe is detriment to this issue.
Andy
The Flying Fox
Hi Jason,
Sorry for the late reply, as you American's would say, "I've been on vacation"
I've got this to work.after a fresh look after my holiday. thanks for the help though, very much appreciated
Andy
glad to hear it is working and that you had some time off.
