java error momento
all kinds of errors I have just installed a new Dreamweaver CS5 nd extentions and momento are not working see attached photo's Im as a loss as to the solution
The first 2 screen shots are errors from another vendors extension.
We do not have an extension named easy rotator, that is from another company.
for the Memento error:
Go to WebAssist -> Preferences in the Memento section Set the Show in dreamweaver option to Never.
In the RSS Section, check the option to disable all RSS Feeds and Check For Updates only when Memento opens.
Then go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
what extensions, including the version numbers, are installed?
